Create Tag Name from File Import - Crimson 3.0
RedLionNewbie
Jun 2016
Tennessee
I have a programming issue I am trying to work on in Crimson 3.0. I want to know if it is possible to import text from a file(xls, csv, txt, etc.) either from the network or from the memory card itself and have it display as the text on a button on a page as well as be linked to a data tag. The reason for this question is that I am trying to create a generalized defect tracking page in Crimson and then be able to use that generalized page for multiple machines and not have to program individual buttons for specific defects and tags for each individual machine.
If I need to better clarify, please ask and I will try to answer as best I can. Or if there is another thread that is similar to what I am trying to do, please post to this thread as I have been looking for some time on the internet and this site and have not found out what I needed to make this work if it is possible.
Thanks in advance for the help and stopping by this thread.
Have a good one.
Thanks,
RedLionNewbie
Have a good one.
Thanks,
RedLionNewbie
There isn't enough information for me to help you with this except to say that I recommend against trying to use a single page to handle multiple machines.
If the structure of the data and the control functions are all the same - just on different machines - I would recommend setting up a Folder Structure Instance for each machine and then creating a Widget containing all the buttons, text, and data tags that is based on that Folder Structure. Then you can put the widget on multiple pages, with each one bound to a different Folder (machine). You will have to have multiple pages, but the widget will only have to be built once.
If the data structure is different between the machines, neither this nor the method you are considering will work properly.
If this doesn't make sense to you, study widgets and folder binding in the manual.
Thanks JHarbin for the response. What you said makes perfect sense. I just wanted to be sure that there was not a way to simplify the programming I am working on for future expansion to other machines and processes.
I will probably be better off anyways creating a Widget like you stated and go from there.
Thanks,
RedLionNewbie
Is there a way in RSLogix 5000 where if I have a bool tag called "robert", and then I wish to change it to "tom", I can prevent from having to...
20
17,926
Good Afternoon, I should know the answer to this . I have a 1756- 4-20 ma input card with spare inputs .I would like to add a new Analog...
1,857
Greetings: I am moving a large SLC program to the CompactLogix platform, and would like to have the FactoryTalk tag database modified and ready...
2,490
i would like to think i am a fairly capable fellow, but when i load the 'NEW TAG' dialog box... click '..' to search for data type and go to...
11,922
Hi All! Boy would it be convenient to simply export my RSLogix 5000 tag database, convert it using a convenient utility, maybe massage it a...
4,775
