Creating Control Tags for Motor Current etc....
Harmonizer88
Dec 2015
Richland
Hello friends! I am new here!
First question is:
I am trying to make a display to control an agitator using a Pflex 525 and I do not see a control tag that will show me the output current of my drive.
There was a previous 525 motor where this was accomplished. The K_9000 motor has this control tag but how do I know it is connected to the 525 actual output current output?
Here are the two displays, K-9000 is my reference, M-3800 is what I a constructing.
These are the control tags for K_9000 which is a 525 VFD
Here are the control tags for M_3800
How do I create a control tag that shows me the M_3800 output current? How did the guy before me do it for the K_9000?
If you are controlling the drive, or just want status, over a communications network, open up the drive properties in the controller organizer, hit the "Change" button under "Module Definition" on the first tab.
From there, you can select up to 4 additional "Input Data" (feedback) values, and 4 "Output Data" (command) values to be read and written to the drive.
Note that you will probably have to do this offline and re-download the program, as these are actual changes to the module (drive) definition.
Hello friends! I am new here! First question is: I am trying to make a display to control an agitator using a Pflex 525 and I do not see a...
2,251
Hi everyone, I am trying to create a medium sized Citect SCADA project utilising a Control Logix PLC. I want to adopt good practice from the...
2,350
Does anyone know if Control Plus software used to create SAMA drawings still exist? IF so, please post a reply where I can find/buy the software?
1,329
Can anyone recommend a book, publication or website for learning to create control panel wiring diagrams? I know there are standard electrical...
1,602
Hi all, I am wondering if it is possible to create a keypad that can be used by an operator to give each data log a name and equipment number...
3,722
