Crimson 3.0 Question
sharkyh2o
Dec 2013
Snow Shoe
129
Hello, I am trying to use the animated image core primitive on a load screen. Not sure how i display more than 2 images. I would like to display 8 images in secession. Just killing time on a power up until my ml1400 is in run mode.
See screenshot below.
DispCount is a counter that increases every time the screen refreshes. You can change the divisor to change the image change rate.
Just wanted to offer that there is a more direct way to animate. Simply use DispCount.0 or if that is too fast use DispCount.1 or DispCount.2...
Cool. Used TimeNow and flipped through the Images. I used DispCount But it was much to fast. If i assigned DispCount.X it just toggeled between 2 images. I like the divisor. gonna give it a try.
I'm sorry, you are correct. I fired before I aimed.
Here is what I have used to cycle through 10 images, but as you noted, it might be too fast
DispCount % 9
Hi Everyone, Hope you all are safe and well. I have a question about creating a Data Log snapshot in Crimson 3.1. I have created a HMI screen...
2,780
Can you program the Help button on the Alarm Viewer to go to a different page? I want to create a separate page with the alarm details on it.
1,227
Hey folks, looking for a bit of help. I have a G15 HMI, I am using Crimson 3. I have created a program with contents: if (Type == 150)...
1,731
I just started working with Crimson 3.0. I have an animated gauge and it works fine but the needle is too thin. Is it possible to make the needle...
2,599
I created a widget with several numerical display primitives. I want the user to be able to tap the widget, which will then show a popup screen...
2,154
