Cross ref report RSlogix500
Christoph
Sep 2003
Indiana
345
Trying to print a cross reference report on 2 data files
N60 & N61. Not having much luck with the report options
tab.
Open Report Options:
Double Click Cross Reference:
Preview Report:
Open up the report options, deselect everything except cross reference files.
Then on the left hand project tree, click on the cross reference icon.
When the new window opens, chose the select files option. Then deselect all files, then select the two files you want.
Edit:
Never mind Mickey did it better.
What is the difference between cross ref and find all?
3,434
In either the Simantic Manager or in the block editor. Using the menu commands: Options Reference Data Display Error= "Error creating an empty...
1,689
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
137
In our production plant we have multiple different networks (subnets). IT dept have setup routing between them so different subnets can...
119
Is it possible to connect a PC with running WinCC Advanced or Unified to a siemens PLC such as S7-1200 across different subnets? The computers can...
98
