Crouzet Millenium 11 Language
Alyoung
Oct 2002
I have a machine supplied with a Croutez Millenium 11 SA12 PLC. The menu language is in French, and I'd like it in English. Does anyone know how to change this, or the address for Croutez web site, as the one I have seems to be a dead link?
Dyslexia sucks, don't it...
"Croutez" has changed their name... It's now "Crouzet" (only kidding)... :p
Try HERE for their current website. It doesn't look like the manual is available there, but maybe the demo software will have a help file? I'm sure it's just a menu selection, so you may want to try writing down the french menu selections and translating them HERE.
beerchug
-Eric
Hmmm, seems that the Millenium II is identical to the Mitsubishi Alpha. Therefore, you should be able to use the manual for the Alpha which is HERE (1.4MB PDF)
Other manuals related to the Alpha (AKA Millenium II) are HERE
beerchug
-Eric
I have also noticed that the Crouzet and the Alpha seems very much the same. I have the Programming software and cable for a Crouzet. Does anyone know if it can be used for programming a Mitsu Alpa PLC??
If I remember correctly, the software installs in French by default (thanks for prompting me).
When I installed this software, I had to fumble my way through the menus until I found the language option. I don't speak French, but finding the right option wasn't too tough. The menus may not be in English, but they follow the "standard" layout. As long as you're not connected to the PLC, your chances of breaking anything are very slim. Take a quick look at the pull-down menus. Most menus go something like this: "FILE EDIT OPTIONS."
AK
Hey all, I hope this is the right place to post this sort of question, I am new to the world of PLC's, and I recently got ahold of an older...
3,776
Hi there, I wonder if there is somebody familiar with Millenium 3 programming. I have a temperature that i want to average continously, for...
2,346
My customer wants me to alter a timer in a millenium 3, But I can't access because of a previous contractors password Anybody got a way to...
5,440
Hi@all! I need some help concerning a Crouzet Millenium 3. I want to build a control system for 3 hydraulic pump stations. The outputs of...
6,263
hello everybody I have a small crouzet millenium plc and I try to make an alarm with real time clock to turn on an output for 1 sec and then...
5,734
