Cup Infeed problem.
gappvembe
May 2007
MI
81
Hi again.
You may have seen the picture below before, it is the same machine just a different approach. For the life of me I can not get consistency out of this program.
What I want to do is, during the time the Electrocam PLUS 7 (I:3/7) is on I want it to turn on the star wheels (O:5/14) in the the 4 pack program, I want it to rotate enough for two cups [Start at one point of the wheel and stop as the Eye (I:1/31) sees it the second time].
My original idea was to to have I:3/7 [Star wheels on] on roughly 3/4 time it needed and have it spin until it sees the eye again...
... But it seems to over shoot the the eye every once and a while.
I then tried attaching a counter to it so it would only spin to the second point... but again that failed.
I'm really at a loss. Any help would be greatly appreciated.
I actually came up with something that works!
The only issue now, is every once and a while (NOT EVERY TIME)at the end of the cycle it will only allow one cup to pass, not two...
Hmm....
You might want to try using a OSR (one shot rising) after I:3/7 where it triggers your counter, this way you will only get one count for each input going true. You can get multiple counts depending on the scan time.
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
290
Hello everyone, I have a SLC 5/03 with two racks, the first with 10 I/Os and the second with 12. The CPU intermittently restarts looking like it...
2,235
Hi I have a 317T-2dp CUP WITH CP343-1 Lean. it was working good. i see some blocks are different between the online and the offline via compare...
1,559
I'm hoping this is a fairly common problem that someone can answer quickly. When testing an Intouch app with window viewer, I noticed that while...
1,807
Congrats to any Black Hawks fans out there. Now the longest run of futilty belongs to my beloved Maple Laffs. New York ended their 50+ year...
1,469
