Curious
John Morris
Sep 2015
San Antonio
689
Studio v31
FTV v10.01
Found the logic was acting backwards. so I switch the name plates on the three way "Control Mode"
Right is the FactoryTalk View .apa
Left is the .mer
I have created runtime 3 times and have been unable to get it to switch.
Three way condition, Multi state indicator, grouped with three momentary switches, grouped behind, and a animation"Visibility "
To contrast the switch on the right, "Direction" was also labeled backwards. I switched the REV and FWD, Created a Runtime once and it took. The switch condition is identical, with the exception of one less momentary push button.
Ill post the resolution if I can find it before you geniuses
Otherwise an help making me feel completely stupid for overlooking something simple, would be greatly appreciated:p
Tried to Create at various levels of grouping just before losing animation, nope didn't change, still backwards.
I changed the logic. (moving on).............................>>>
Ill throw some more time at it later. see if i can figure it out.
Silly suggestion...
Check the file date creation on the .mer file... is it changing to the date/time of the most recent creation? Maybe your brand new ones are going to a different directory for some reason? I just thought I would start with a basic thing you could check...
Good suggestion
I checked the ME runtime file under RSViewEnterprise, all the creations are numbered and in temporal order.
Thank you for the suggestion
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
178
I'm focusing on Rockwell programming for a couple of projects, and I've been thinking about some of the details I've come across while working...
2,327
Hello all. I was starting to get into a new project (that will probably never see the light of day because $$$) at the plant I work in and...
26
5,571
Just curious, Have you noticed how the Honeywell C200 and the A-B Controllogix look alike? Are this two related somehow? Are they compatible...
2,041
Hi guys, I never worked with wago I/o remote module. In our plant we used 4 no of wago module. The old module is 750-341 and now we keept as...
3,536
