kolyur
I'm connecting an output from a stepper motor driver to a DC input on my PLC (Micrologix 1500). The control voltage is 24V. As indicated, the current through the driver's optoisolator can't exceed 10 mA.
Originally I was thinking I'd have to put a resistor in series with the signal line (R2). But looking at the input specifications for my PLC, it says the on-state current is 7.3 mA at 24v, and the nominal impedance is 3.3Kohm (which is approximately the resistor value I calculated I'd have to use).
Does this mean that I can connect the signal line to the input without an external resistor? That's my gut feeling but I just thought I'd ask since I really don't want to fry the driver.
