Current signal conditioner
allscott
Jul 2004
1,332
I am looking for a signal conditioner that I can run a motor lead through to turn on a relay output (somewhere around 9A) to take into a PLC input. It needs to be quick switching (less than 100mS) and have an adjustable setpoint.
Anyone ever used such a thing or know of a manufacturer?
Hi, What is the reason behind the 4-20mA current as a standard signal for transferring data? Well for starters, we choose current over voltage...
6,886
Hello to all, I need some kind of hardware filter with possibility to adjust damping from let say 1 to 5 sec. I need this to try to smooth mA...
3,586
Hello, What distances can we transfer the 4-20 mA current signal? What distance do we need to use a shielded cable at? What cable should I buy...
5,237
Hello guys, I'm not sure if I used correct term in the topic's name but basically I need the following. I have one pressure transmitter that gives...
2,800
Today I was working on my project for school and we were using a power supply with 24V and we accidentally had the current at 0.9A. We heard a pop...
564
