Cut to Length Application
JamesWSY
Jul 2005
Jakarta
81
Hi..
For cut length application, how to define accuracy of cutting length (we need +/- 1mm)? I used compactlogix with 2048 ppr encoder and measuring wheel diameter is 127mm. The drive unit is using ControlTech Unidrive SP2402 c/w dynamic braking resistor and vector motor. Maximum speed is 30 MPM, maximum cut length is 1800 mm. How to convert pulse to length?
Compactlogix will generate speed ref to unidrive and if actual length reached 90% and motor speed will slowdown and stop if actual length reached setpoint.
Any idea or suggestion?
Thank you.
James
You count the pulses per unit of measure. IE 200 pulses per 10 MM. Then have the control count the pulses. You will need to put cut values into memory locations and use compare functions of desired length. when you achieve the 90% you initiate a decel and creep into the stop point. You may need to have a back into position if excessive over shoot occurs.
BTW, you may get better results using a 4096 count encoder. More counts can provide better resolution/accuracy.
What's the best ladder logic programming design for a cut to length machine? I would like it to have at minimum run,stop and jog function. Could...
26
18,841
Hello, This is my first serious PLC project. I'm self educated, and trying to build a servo driven cut to length machine for our shop. I'm using...
10,869
Hi... I have an cut to length application using vector motor and powerflex700VC. Line speed is 40 MPM, cut length is 2000 mm +/- 2 mm and type of...
27
10,260
Our customer has a Hydra-Draw machine. This machine pulls coiled steel rod through a die and then cuts-to-length. The hydraulic cylinder is...
2,784
Hi... I want to using Unidrive SP2402 for cut to length machine with running speed at 30 meter/min. I use AC motor (c/w 1024 ppr encoder as speed...
5,150
