D-Sub Right-Angle Adapter
bernie_carlton
Apr 2002
Yakima, Washington
6,413
Does anyone know of a source of right-angle D-Sub M-F adapters? (Display mounted too close to control buttons for proper access by communication and programming cables.)
Are we talking 9 pin, 15 pin, 25, or 37 pin or a combo?
Check with Newark, not sure about having the adapter but probably have a right angle connector.
I'm thinking that if the RA adapters don't exist then I'll probably have to do with a couple of IDC connectors with a short piece of flat cable. Ah, well.
You know, I was looking for these a LONG time ago, Bernie. I wanted them for the EZ-Touch panels. I don't use the EZ-Touches anymore, but in the interum, I FOUND A SOURCE FOR THE CONNECTORS!... (y)
L-com makes them for DB9 and DB15-HD, left or right exit as well. THIS link should take you to that page, but if not, you can navigate to the D-subminiature/Adapters section from the main page. They're cheap too!... :cool:
-Eric
Hi guys, I am creating a sub routine and was wondering how i can trigger Bit when the sub routine first runs is it just a Open Line ? or is the...
805
Hi I hope all are doing good I have some doubt on FTV VBA coding for Drop down list. I wanted to know how to build a VBA code for Drop down list...
1,013
Context: Mitsubishi GX Developer/GT Designer 3. At the moment on our PLC's HMI (GT Designer 3), pressing any of the SCREEN buttons will navigate...
1,896
Hi, I have siemens SM1231 RTD module, the temperature I need to read is sub zero. The input is 15 bit plus sign, anyone can suggest the easiest...
2,654
