data blocks
panthripu
Mar 2004
228
can someone tell me in details about the data blocks.What is the use? where can it be used? and how to use db with fb?
Hello, panthripu;
A DataBlock (DB) is an area of S7 CPU memory than can be reserved and configured for the use of a program. If you use a "Shared DB", you configure it for your own needs. If you program a Function Block (FB), an "Instance DB" is generated, based on the structure of the memory requirements of the FB.
I suggest you read (and practice) a Siemens document called "Working with Step7"; it comes in PDF format and is included with the documentation of your Step7 (Start--> Simatic--> Documentation--> English--> Working with Step7). This should give you a good start.
Hope this helps,
Daniel Chartier
i my friend
Hey Daniel Chartier. Are you from Montréal. Where you work?
I'm working for electrolux in east suburban of montréal
Hi everyone, I am normally not in Siemens PLCs, so I have a relatively beginner question. In a data block (DB3), I added a few rows to it. When...
1,986
Hi everyone i have uploaded some machine programs, what i noticed is that the programmer puts the inputs in a data block and work with this data...
5,002
Hello everyone, As you can see in the screenshot below i have some values that are retentive. Now i want to create a specific value for specific...
1,532
Hello all, I am trying to read DB values from an S7-300 with CPU 317-2 DP. I have done this before with a CPU 313C but it had a CP 343-1 Lean...
4,851
I have a function block (FB1) which uses internal tags and has made a data block (DB1). I have a created a PLC data type with around 15 tags and...
1,699
