Data Entry on OP270 ProTool
koti
Mar 2005
Hi Everyone!
I've got an existing system with a OP270 using ProTool. They added some temp sensors on it. What I need to do is add a screen(s) where I can enter High & Low limits for acceptable temperature. What means would you suggest?
BTW, this system is for Ford which uses Transline (a predefined hmi/plc architecture). But fortunately, I do not have to adhere to it for this addition.
Thanks!
Make an Invisible field BEHIND the object that dispays the temperature, and make it open another small screen (not maximized) and add your editable integer fields there).
(No major screens added)
It's the "editable integer field" that I'm curious about. What method would I use to input the value? Is there a way to use the keypad or should I rely on the function buttons on the sides. Or can I use a slider...though I don't know how to make it function using the function keys...yet.
Hello, I am pulling my hair out trying to setup Modbus Master Read/Write Commands on a Prosoft MVI56E-MCM attached to a Clogixs 1756-L82E PLC. It...
1,583
I have a colleague working on a system with a Siemens S7-1500 PLC, a Siemens TP1200 Comfort HMI programmed using TIA Portal V15.1. He is trying...
3,258
Hi! GE proficy numeric data entry animation issue.Im not able to find where i can use tag for visibility.
1,249
I put a Numeric Data Entry Object(NDE) on my screen. Then I made a rectangle(solid pattern). Moved the rectangle over the NDE and set the...
1,596
Hi, I have a Red lion HMI using crimson 3.0. I have a data entry box which has a value entered by an operator. I would like to create another data...
3,663
