GE proficy numeric data entry animation
If you are using the standard Numeric Data Entry item, there is no animation including visibility.
If you use a button, you will have animation objects.
If you have the Inspector window open, any object that has animation will have "Animations" on the general tab.
For further information on what objects support animation, search the help for animation, then open the topic "Animation: an Overview".
The page shows a list of objects for each animation type.
I put a Numeric Data Entry Object(NDE) on my screen. Then I made a rectangle(solid pattern). Moved the rectangle over the NDE and set the...
1,581
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
50
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
105
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
97
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
71
