data from powerLogic pm9c by mudbus
phinix
May 2006
l.a
33
hi u all,
i am trying to read data from a merlin Gerin powerlogic pm9c
i am using a laptop ,adam 4520 converter(485-322)and a modbus opc server.
i know that the device is transmitting by rs485 modbus rtu and i have configured it to work.
i know that the adam is converting 485 to 232
i know that the opc server should communicate with the device but it dosn't.
i get a device comunication error on the server
needless to say all baund rates and address are the same.
dear people please help!!!
Read pairs of registers starting at an even number
CAN ONLY READ PAIRS OF REGISTERS STARTING AT AN EVEN NUMBER
There is a trap! If You try to read one register you will get an error. If you try to read a pair of registers starting at an odd number (e.g. 1001 and 1002), you will get an error). If you try to read an odd number of registers you will get an error.
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
55
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
76
63
175
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
79
