Data tranfer from SLC5/05 to CL.
MGuenette
Jan 2007
Montreal
134
I looked on the forum but i did not find any answer about if it's or it is not possible to transfer date from SLC5/05 to controllogix. Both PLCs are on ethernet
I would like to tranfer some integer to get all my production info in the same PLC.
Martin.
Please give actual article numbers as clicking on that link takes you to a login page. Even after logging in, there is no forwarding to the page/link.
MGuenette said:
Martin.
Are you trying to sync the clock on both PLCs 'date', or are you just wanting to pass 'data' ?
Ian
Ian
Passing data.. The packaging area works with SLC5/05 and I want to trak the number of produced cases to the ControlLogix where I remote each downtime of the machine.
Martin.
Martin.
This is a screen shot of an ethernet read from a SLC 5/05
If the contrologix controls the reads and writes, there is no need for a mapping table, but of the SLC 5/05 controls the messaging, a mapping table is required in the contrologix
Ian
Ian
You are absolutely right. Sorry I only do reads thats why I use the mapping when going the other direction.
Yes, its annoying. However, if you login and come back to this webpage and click on the link again it will take you to the right technote.
Thanks,
but in the case of i just read an integer in the SLC like N7:7, do I need to setup something in the SLC?
also, what I need to put in the "path" dialog box"
I found this on the ethernet, but I cant find any explication
Slot_1, 0, 172.30.16.80, 1, 1
thanks
Martin.
MGuenette said:
Thanks,
thanks
Martin.
From the online help files
I have this
So I want to read the integer N7:7 in my slc-5/05 at the address : 172.30.16.80. The Enet cable is connected on the processor (slot 0) and it's the port #2.
I want to read only N7:7 so I writed "1" in "number of elements"
I want to write this number in "z_nombre_caisses".
It should be right?
Thanks for your help...this little thing drive me crazy!
I always have communication failure
Here's my RSLINX
Martin.
Finally it works,
I just undurstood what was the problem.
Whats was wrong :
"backplan to read", "port to read", "IP to read"
instead of:
"backplane from", "port from", "IP to read"
Buy reading your email and looking at your IO tree, I understood.
Your help have been really appreciated.
Thanks again!
Martin.
Dear All. I want tranfer a value tag ( LREAL) from simotion to PLC s7-300. in PLC i have SFC66 to Receive data, in simotion i called block _Xsend...
2,634
Hello Everyone, I am using a raC_Opr_NetModbusTCPClient AOI module, as below,. So, I need some assistance to restrict in reducing the poling...
53
Hi everyone, I have a 505 workshop program with PLC type of 555- 1106 and I was wondering how can I download the data documentation window as a...
139
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
72
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
80
