datasheet claims relay output is "Form A - Normally Closed"
Form A is Normally Open
Form B is Normally Closed
Form C is Both
I thin what they mean is the relay is a Form A N.O.
the relay is energized and held closed I normal operation in an alarm condition the relay deenergized and the output is turned off kind of like a fail safe if the device is not powered then it would set an alarm in whatever control is monitoring it.
Form C is Both
I concur. Back in the olden days we called them NOHC contacts (normally open, held closed).
All, I have an older machine which uses Bosch Rexroth proportional control for pump tilt and relief. The pump would not tilt. We tested command...
1,110
Hello, I was looking at a datasheet for a sensor thats going to be used in a safety related application, I was interested in a B10 or B10D value...
3,172
Hi, I have been looking on the internet, but I cannot seem to find a datasheet for Tamura Power Supply Wes 24 G U DC 24V. All I need to know is...
2,999
Pls can somebody give me link where to download pdf broshure for Allen Bradley 1761-L32BWB series MicroLogix 100 PLC? I`ve been searching trough...
5,158
Hi, Does anyone knows in which website address that I can download the DATASHEET or CATALOGUE or information sheet about TOAHIBA PLC for the...
1,894
