DB9 Hood Right Angle (compact)
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
I ordered some hoods (backshells) for a DB9 cable that needs a tight right angle and when they arrived, they turned out to be a very poor fit. They are over 1-1/2" long and have a 45 degree cable exit... I only have about an inch maximum.
Does anyone know of a supplier or a part number I can order for a Sub-D 9 pin connector hood that is compact?
I need the thing to be less than an inch from the connector edge to the back of the hood and have a right angle cable exit.
I have searched the web until I am going cross-eyed, but haven't found anything that is a for sure fit. I have bought some cheap plastic clamshell style hoods in the past that would have worked, but I can't remember where I got them.
Paul
Paul
http://www.l-com.com/item.aspx?id=8658
use this an a straight radio shack dB9 for your caable.
If this works for you, you must thank Bernie for the link!!!
Actually I remember that. While I didn't use the L-Com adapters in that particular instance (they had to redesign the enclosure for some other reason that I forget) the company came in hand later for some other adapters. They have literally everything. (Instead of figuratively everything)
I also was looking for a low-profile right angle DB9 hood, and recently found a good solution that I thought I'd post in case anyone's interested. Allied P/N 810-0075 works great for my application (a Red Lion G306K) and protrudes exactly 1 inch. I also drilled a hole in the side so that I could use two of the cable conductors to power the unit.
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,572
Hello guys, I am trying to control a ATV12 via Modbus Poll software. I need the connection diagram for Altivar Modbus RJ45 port to DB9 port. Thank you
576
Hello everyone, How important is it to obtain cable pinouts from a vendor whem connecting a device with DB9 connector to a device with DB25...
2,657
Could someone point me to a DB9F right angle cable that would allow me to close the door on a L61 PLC? Certainly one exists but all I can locate...
1,790
We have a cable with two male db9 sides. The connected pins are: 2 to 2 , 3 to 3 , 7 to 7 , 8 to 8 . What could be this cable type...
3,162
