Dc Drive
PERSPOLIS
Jun 2002
ontario
295
HI dc drive experts
what are the steps required to program a dc drive for a dc motor in general. There are many parameters that are not required to look at nor to program Thanks a lot
It's difficult to give a general answer as the variety of drives available offers a wide range of different programming parameters.
Some lower end drives only have a few potentiometers to set current limit and maximum voltage, while others have complex control strategies based on function blocks.
I would say at the very least you need to provide the motor voltage and FLA, field voltage and current and motor RPM.
Regards
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
332
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
86
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
68
Hello everyone, my son and I are working on building a metal lathe. I been waiting for a motor/speed controller donor from a treadmill. I finally...
69
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
88
