DCD equivalent in Rslogix5000
42004 - How to implement RSLogix 500 DCD and ENC instructions in RSLogix 5000
Access Level: Everyone
Regards,
George
Hi George,
That is great. but i do not know which tag will be filled in the first operand.
please see the picture.
Thanks so much,
Khang.
please see the picture. [...]
We cannot see that image; it needs to be attached to the post, using the
button when writing a post in Advanced Mode.
The first operand to that AOI is TagSource; that is the input INT; the first four bits of TagSrouce composw the position (0-15) of the bit to be set in the second operand TagDest.
@daba's is still the best, but here is another in line with the TechConnect approach but more concise:
Code:
MOV 2#1 TagDest
XIC TagSource.3 MUL TagDest 2#100000000 TagDest
XIC TagSource.2 MUL TagDest 2#10000 TagDest
XIC TagSource.1 MUL TagDest 2#100 TagDest
XIC TagSource.0 BTD TagDest 0 TagDest 1 15 OTU TagDest.0
the BTD protects against overflow on multiply
I am unclear about the "OTE tagname.[source]" portion of this. OTE is a boolean and my datatype for the source is DINT.
For example:
If my source is N7[53] and my tagname is N20[49], would that mean that i place an OTE that is tagged N7[53].N20[49] ? I'm confused.
One issue you have is that the conversion from Logix500 has created "Array" tags. In your case "N7" and "N20" and your code is addressing elements #53 and #49 respectively.
Array tags are not easy to work with, so I suggest you create "Alias" tags ...
eg.
INT type "MySource" as an alias to N7[53]
INT type "MyDest" as an alias to N20[49]
Then your DCD equivalent will be...
CLR MyDest, LIM 0 MySource 15, OTE MyDest.[MySource]
Put these instructions on ONE rung, so they cannot get separated by edits.
How can I achieve the same functionality in Studio 5000? Image 001.png for the old RSLogix500 program Image 002.png for conversion to Studio...
2,528
Good afternoon to all Need help in understanding the purpose of a case state "decode 4 to 1 of 16" any help is greatly appreciated. Thank you
1,628
:shoot:I am wanting to take a word and say chop up the hex value ie. word b9:0 = DCA9 send the 9 - b10:0 then A-B10:1 then C-B10:2 then...
3,297
Hi Everyone, I am working on a project with a SLC504. I am using the DCD instruction to use 4 inputs to select 1 of 16 outputs. I have tested my...
3,248
I am replacing a old plc in some used equipment. I would like to keep the drawings close to the same,and the control wiring the same. I have a...
1,779
