Dead SLC 500 5/04
DFJ
Aug 2005
Washington State
23
I just started using a slc 500 5/04 processor and after a few days I am unable to communicate with the processor any more. I get a solid Fault light and have not been able to communicate since. I have checked all cabling and tried new cables with no results. I have a slc500 5/01 processor that works just fine. Any ideas?
Take a look at these...
In 5_04 fault2.pdf you are shown how to reset the cpu to factory settings.
Have you recently tried to upgrade the firmware leading to this failure?
How are you communicating with the 5/04 and 5/01?
A solid (not flashing) red Fault LED is usually an indication of a fatal processor problem so don't be surprised if shorting the unit doesn't work.
I had made a change in the configeration of the rack a few days before, but was able to talk to the processor several times after that. I am talking to the 5/04 with a NULL MODEM cable and have tried to talk to it with DH+ from another computer with the same results. I use a 1747 PIC to talk to the 5/01. Thanks for post, I will look these over and let you know.
Just wanted you to know I was finally able to get the processor breathing again. Thanks for the input, I realy appreciate it alot.
Dave
I've got a SLC 5/05 cpu that appears to be dead. By looking at past threads dealing with similar problems, and trying a few things, I'm heeding...
5,171
I have an A/B SLC 5/03 1747-L532 that I'm trying to upgrade. The OS on it was erased and I finally got the firmware update ROM. The battery on...
5,072
Anyone ever have an ethernet port just puke out on one of these? This processor is in a test rack in a perfectly suitable environment and was...
4,918
Had a callout today, machine I built in 2019 (Feb) with a 1769-L16ER-BB1b. Major fault, local IO module (there is no point attached). Reset major...
2,255
I've had a laptop die on me, with a win7 install. Bad news is, S5K had borrowed a license from a dongle onto it, then it died. Have installed S5K...
2,277
