Deleting an Add-on Instruction RSLogix5000 V16.00.00
I know I'm playing necromancer as well, but heresgeo nailed it. I'm newer to Rockwell and newer still to AOIs, and I didn't know the "trick" to finding all the cross references for AOIs. All the previous posts only got me part of the way because I didn't know about the Add-On-Defined references.
If the "Cross Reference" to the Add-On-Instruction shows no references, but you still cannot delete it, look under "Data Types", "Add-On_Defined". You should see the name of the AOI. Right click that and select "Cross Reference". This will show you where the data type of the AOI is being Aliased. Get rid of that tag and then you will be able to delete the AOI.
Thanks for the write up heresgeo, but even a cross reference shows zero use of the AOI, yet I cannot delete it still. theColonel26 finalized the answer, definitely has to be offline to delete, then download to controller.
Hi, I have a s7-1200 at home that went into "CPU error: Serious firmware exception". After a power cycle it was OK again, but all retained data...
850
Hi guys, Working on one of my client's systems with SLC processors, earlier today she called me and said she was having comms errors, had a solid...
2,054
Hello EtherCAT gurus. Is it possible to delete the EtherCAT Stack Code information from an EtherCAT device using the available Windows tools...
1,288
Hello: Richard here, new to the group. We are learning Studio 5000 in my advance PLC class at school, but greatly limited by not being able to...
1,758
All of these processes are taking all day to run. When doing the same operation in a stand alone intouch application it only take a few minutes to...
1,615
