Delta plc Ethernet network
Ramin_shb67
Apr 2015
Shiraz
Hi
I want to connect 20 Delta PLC (DVP12SE11R) to an engineering system and read PLCs parameters in Citect Scada
how can I do it?
I dont have time.
plz help.
Thank you.
Greetings,
The first thing you will want to verify is that Citec has a driver for Delta through the software's server.
Second, you will want to determine how you will establish your hardware connection of these multiple devices - wired or wireless.
If you are going wired, you will require an Ethernet switch or router, depending upon the functionality you are needing.
A product such as the Lynx 110 from Westermo would be a product to consider, if all you require is layer 2 Ethernet functionality. If you require layer 3 and firewall, then the Lynx 210 would be a consideration. More information regarding both can be accessed through the following link to our web site...
http://www.eternity-sales.com/Westermo/lynx_managed_ethernet_switches.htm
If you are considering a wireless connection, we also have a vendor for that. More information can be viewed through the following link...
http://www.eternity-sales.com/WirefreeCNC/WirefreeCNC.htm
If you have any questions, feel free to post, pm or email through the link provided in my signature.
Mr. Stephen
Thank you for your attention.
I cant find driver for Delta PLC in Citect SCADA and I dont know how can I find and add this driver to citect.
my network is ethernet(TCP/IP or Modbus TCP) and wired
but first I have to learn how can I connect delta PLC(DVP12SE11R) with citect.
I was really wondering if I could receive some of helpful response.
Kind regards
I'm working on an DELTA PLC project and I'm trying to use modbus library to connect to plc My first test is with a Delta DVP-12SE11R PLC and the...
4,372
hello I bought new plc dvp es2e and 12se I need them for the ethernet in them Now every plc comes with a default ip addreas and tcpip port In...
2,978
hello dear we have a problem with communicate with delta dop hmi and siemens s7-300 cpu . we use ISO ON TCP connection and AG-SEND and AG-RECV...
3,500
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
54
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
126
