Delta PLC problem
mhmd.sh89
Jul 2016
beirut
Hello everyone
I have a DELTA PLC DVP20EX2 and I want to use Real time clock in my application.
In the manual they said that TCMP instruction compares the value of rtc with a preset value .
TCMP S1 S2 S3 S D .
S1: “Hour” for comparison (K0~K23)
S2: “Minute” for comparison (K0~K59) S3: “Second” for comparison (K0~K59)
S: Current time of RTC (occupies 3 consecutive devices)
D: Comparison result (occupies 3 consecutive devices)
example
AF1QipOrdZvg5GFAX4BD1QwL0MkzL0f82gWteHvxazdB
but the problem that the S register begins with seconds not hours to compare those 3 registers.
thank you
Hello,
you mean that I should read the time clock and put it in decreasing manner instead of increasing ?
Regards,
Hi, I want to communicate slc5/03 cpu with Delta tp04 hmi through rs232 port. I tried through 1747cp3 cable directly but can not communicate...
937
Attempting to connect PLC Delta DVP12SE to VFD LS SV075iG5A-4. PLC COM2 LED is flickering but no response from Inverter :scratch: This is my first...
7,430
hello I bought new plc dvp es2e and 12se I need them for the ethernet in them Now every plc comes with a default ip addreas and tcpip port In...
2,984
I am trying a real simple program here. I've give DPLSY instruction to Y0 and made a wire connection so that the pulses at y0 output are reverted...
1,970
Hello everyone I have a DELTA PLC DVP20EX2 and I want to use Real time clock in my application. In the manual they said that TCMP instruction...
1,228
