device not responding
blackslipper
Nov 2005
North Carolina
47
Hi
I am tryin to use the OPC Quick Client, however I am receiving the following error:
Siemens S7-200 Device 'Channel1.Device1' is not responding.
can anyone assist
Is this kepserver, if so you either have a setup problem in the opc server or your interface or lead is not connected correctly.
Check the comms settings, correct driver loaded etc.
Hello. After installing the latest Codesys V3.5 SP17 Pach 1, Win V3 x64, on some of our Windows 10 workstations it is impossible to load a program...
3,116
Hello everyone. Please I need help with configuration on my rsnetworx for controlnet. I get a message that says "No device is responding as the...
2,773
Hello guys! I have a problem with reading tags from S7-300 with 343 module. I checked siemens communication settings hundred times with kepserver...
5,027
Anyone have a idea of what would cause a failure of all nodes (buckets) of an AB Device Net MCC upon a power cycle of the main feeder for that MCC?
208
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
79
