DH+ Interface
I think replacing it with a 5/04 will be the most cost effective way, plenty on eBay used. Or look for a rs232 to dh+ interface but you'll loose channel 0.
Jstolaruk is probably right, replacing your 5/03 with an 04 is probably the easiest by far.
Potentially though, and I say potentially because I'm not at all sure, and coordinating the two may be a HUGE pain.
Prosoft MVI46-DFNT card to allow your 5/03 to communicate through ethernet, or some other device that does such, and then....
Prosoft AN-X2-AB-DHRIO to convert the Ethernet to DH+??
I currently use the AN-X2-AB-DHRIO with my 5/04 to convert DH+ to ethernet, but I dont see why you could'nt use it in the opposite fashion.
You probably would want to look into it more, thoroughly but its an idea if your completely opposed to just taking the easy route and buying a 5/04.
good luck
Max, perhaps you didn't notice that the OP wanted to connect the 5/03 controller to DH+. Not DH485, which certainly has "many ways" of connecting to the 5/03. The 5/04 is another story.
Most methods to connect the 5/03 to DH+ will probably end up being more expensive than just swapping out the 5/03 for the 5/04.
OG
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
66
Hello world! The company I started working for has these valves that they ordered years ago as spares. now we have to add couple valves on...
216
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
925
Does anyone know why the connection interface is greyed out and says why I can only use Teleservice instead of the other options like PN/IE? I am...
242
I am attempting to generate a VBA script within FactoryTalk View SE to open a Google Chrome webpage (PI Vision) when an object is right-clicked...
133
