DH+ Link ID -- how to determine?
Lakee911
May 2006
Columbus, OH
98
I've got an existing DH+ network. How do I determine what LinkID it is using?
I've got a 1756-DHRIO card. It needs its own unique LinkID for the module and then I have to match the network, right?
Thx!
In RSLinx go to the DH+ RIO card and right click to get to propertiesits in there
If this is a new install then I set mine to the same as the node address that it uses
Link ID's are different from DH+ Node Addresses.
Think of a DH+ network like a residential street. Every house has an address, just like every node on the DH+ has an address. I live here in my PLC5 at #3 Oak Street.
There's another DH+ nearby; it's called Elm Street. There's a #3 Elm Street too.
So if I want to send a message to #3 Elm Street from #3 Oak Street, I need to send it through a gateway on my own street, and know which street it's headed to. The Street name is the Link ID.
Now here's the surprise: Link IDs are ignored for local messaging. If I send a message locally from #3 Oak Street to #5 and don't specify which street it's on, it just goes to #5 Oak Street.
90% of DH+ installations have just the one network so the Link IDs end up being left at their defaults, and nobody notices because they never need to send a message beyond Oak Street.
Where you can get really interesting is when you use a ControlLogix and 1756-DHRIO modules to create Link ID's that have a backplane and ControlNet or Ethernet paths between the two DH+ networks. You could separate Oak Street from Elm Street by a wide area Ethernet LAN and they'd never know it.
Where you can get really interesting is when you use a ControlLogix and 1756-DHRIO modules to create Link ID's that have a backplane and ControlNet or Ethernet paths between the two DH+ networks. You could separate Oak Street from Elm Street by a wide area Ethernet LAN and they'd never know it.[/quote]
So, you're saying I could brige two Elm streets with Ethernet and the local PLCs wouldn't know it?
Good afternoon, I have a problem communicating with a system, I will explain it briefly. I have a HIS -ML17- CTBH monitor connected to an...
125
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
117
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
98
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
105
Hey there friends, recently discovered the world of industrial automation and learned what this fancy PLC can do so i am a super novice. Started...
364
