Diesel generator sizing
An oservation, the original poster is in Iran so may not be able to talk with CAT, Cummins, or some generator companies at this time. I do not know this for a fact but it may be something to consider; therefore if you are in the region maybe you know someone that could discuss the matter with him.
I can not come close to knowing gensets like Andybr or BobB but have worked with them a little. If you can not get the exact details then calculate the highest possible load with everything running then multiply it 1.5 (150%) THEN when you go to get a system make sure the genset uses that calculation for its Prime rating and has a Standby rating that is higher. From the numbers given I would think a 2000KW.
This may be a simplistic view that may cost more, not be cost effective overall BUT should allow you to have a backup power system capable of meeting your needs.
The key, as mentioned, if buying new would be finding a supplier and talking with them.
Hi. It turns out running just inverters off of a generator is bad for the generator. Any tips? Ideally I would like to size my diesel generator...
2,478
Hi, I am looking for a sensor to monitor the level of Diesel Fuel And Gasoline in an outdoor Storage tank. The Tank has cylindrical shape laying...
1,873
Hi Gents I am working on a fuel storage and dispensing facility. Initally the storage part was being done by others, and I have completed the...
3,439
Reaching out to all the seasoned folks, what would you use if you were to provide a 300 kW power generation system? A diesel genset or a...
17
6,203
Hi, I'm new here and I don't know is this topic belong here? I would like to know if somebody have experience in putting Beckhoff CANopen master...
3,017
