Diff Bet Quick,data
There are two main differences.
1. QuickPanel has a graphic interface with touch screen.
DataPanel is 'usually' text only diplay, with Function keys, no touch screen.
2. QuickPanel is programmed with Proficy ME View Developer
Datapanels either need no development software, for the most basic unit or are programmed with WinConfig.
Some of the older style QuicPanels can also be programmed with QuickDesigner software.
You can find manuals for all of this here:
http://globalcare.gefanuc.com/search/glbCareProdManuals.asp
S7 diff. bet FB & FC & all data in FB need to be available to any block or only STAT I am newbie in S7. I want to know difference between FB &...
6,590
What happens if you put Ethernet/ip, Modbus TCP, and Profinet on the same network? Do they need to be isolated from each other or can they work on...
3,228
I am receiving attached error on Wonderware 2012R2 Alarm Database.As per InSource, the solution is Tech Alert 118 but its no longer available on...
3,564
dear all what is the difference between SEW BSG 825 459 && BS24 826 763 I asked about the usage as I see the circuit diagram are the same for...
1,354
Tell me if I'm all wet here because I'm arguing with PE but I'm not yet convinced. I have a 20 foot tall liquid CO2 Tank with vacuum jacket...
25
4,864
