difference between instrument cable and control cable
Well, until someone gives you a formal answer.....
I think of instrument cabe, as a small guage fine stranded often sheilded wire for low power signals generally connected to a sensor, meter, display of similar device.
I generally consider control wire to be larger, 14 or 16 guage, sometimes larger, often solid conductor, to connect switches lights, relays, and devices will higher voltages and currents.
I like to use MTW (Machine Tool Wire) which is more flexible and has a different insulation, and is very flexible and easy to work with.
hello fnds wats the difference betwen instrument cable and control cable regards jos
10,806
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,434
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,087
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,992
Hi Experts, Good day! What are the differences between PCS7 SIMATIC Batch and PM Control? Do you have any manual like "Getting Started "...
828
