Direct Logic 205 DL240 CPU comm issue
jeb72
Jul 2013
texas
Hello,
Wondering if anyone could possibly shed some light on an issue with a Direct Logic 205/DL 240 CPU. I'm having zero luck talking to this thing and it's driving me crazy...I'm using a run of the mill Lenovo Think Pad laptop with Direct Soft 5 installed and when I go to "add link" I only see comm port's 1-4, but my laptops comm ports are 9-11 and I am using a RS232 to USB adapter. It doesn't matter which one of the ports on my laptop I connect to, I either get a "PLC not responding" message or I get "cannot communicate with port" message...is there anyway around this? Is there anyway of making a link to the PLC?"
Any help would be greatly appreciated,
Thank you,
Jon
You can also open device manager, find your USB serial ports and force it to com ports 1-4. This setting is under advanced (I think).
Be careful that you don't force it to a port that really has something attached, like your mouse etc.
That being typed, it is better to follow Bernie's link.
Hello All, I inherited a small PLC panel which controls two high pressure pumps when I started as an operator for a small water supplier. I knew...
2,215
Hello! I have a couple years of experience programming Siemens PLCS so I am a bit lost on programming the Direct Logic 205. I would really...
3,536
HI, Hopefully someone can point me in the right direction, the problem im having is with a direct logic 205 PLC DL260 CPU. The PLC in running a...
4,152
Hello, I am a Mfg. Eng. trying to figure why an Automation Direct HMI (DP-C321) has stopped communicating to a Direct Logic 205 PLC. The machine...
4,999
Hi guys, I have a communication problem between KOYO Direct Logic 205 CPU DL250-1 and Weintek EasyView MT506TV HMI touch screen. They have been...
4,696
