Direct Soft SET / RST question....
XtremeIN
Jun 2005
Indiana
217
Hello all,
Simple question here. I know that one should never use the same output more than one time and if someone were to than the last state of that output in the last rung will control it. But what about SET and RST's. I know they can be used in more than one place and work. Would this be considerd a bad programming practice? Even though it seems to work can it cause issues in the program?
Thanks,
Micheal
Like everything, if you do it right, it doesn't cause a problem and is very useful. I do it when running through the various functions of my program to set warnings and faults, or to sense a particular global condition that is to be used by other components.
For instance, I wrote a program once that had a series of about 50 conveyors. When the machine was in maintenace mode, it was permissible to operate only one conveyor at a time. As I looped through the logic, if there was already a conveyor running, I would set a "Conveyor Already Running" bit that would inhibit all other conveyors.
Just line an OUT, the last instruction (SET or RST) encountered on a true rung in an active section of the program (just in case you are using Stage Programming) wins.
When using Stage Programming it is a permitted (and even expected) programming style to have multiple occurances of the same OUT. Just as long as only one stage containing the OUT is active. Otherwise the 'last one wins' rule is in effect.
I have written one program with FDB. Thought I could therefor write code for an automation direct DL-06. Huge learning curve. I believe I have...
1,765
Hey All, I got an older piece of equipment here, controls done with an Automation Direct 06 plc (OEM is long gone). I'm trying to piece together...
2,379
Hello everyone, I have a customer that needs some help and I dont really understand the question so im posting it here, I think he is over...
3,976
Hello all, I am trying to synchronize the speed of two motors so that once an operator sets them both where they want they can push a button that...
2,719
I am working with a DL 205, DL250-1 CPU, D2-16ND3-2 Digital input module. I am writing a ladder that will send the value from the digital input...
1,235
