Displaying data to a large hdmi television
scalelar
Aug 2006
SE Tn
62
I have to bid on a project that displays some shift data on a 70" hdmi tv. I've seen these before but I've lived a sheltered life and haven't been involved. The plc will be AB Logix family. I know wonderware would do it but there has to be a more cost effective solution. Maybe just a web page via an Eweb card?
Any response appreciated.
I'm in the midst of research for a similar project at my plant. Right now, I'm leaning towards using one of these. Appears to be quite powerful, and relatively inexpensive.
This may sound a bit silly but the 12 and 15 inch versions of the AutomationDirect C-More now come with HDMI Out. They're probably cheaper than an EWEB Module and you wouldn't have to buy a PC for the TV.
I am doing something similar where my main display will be a 21" screen, but there need to be a larger (40+ inches) display overhead that shows just one status page.
My HMI software will be Indusoft Web Studio, and I'm going to make the remote monitor a cheap Windows PC that can run the Indusoft thin client.
The benefit of doing this instead of using a ProducTiVity Station or a standalone HMI is that I use the same development software for everything and only need to edit and maintain one runtime.
I have not implemented the whole thing, though, and I'm not certain of the resolution changes when I go from running a native thick client to running a larger thin client.
Ken, why not use a consumer TV in a custom enclosure, the enclosure built so you can swap in a new set, access the buttons, power and HDMI signal cable, and put it in required environment and keep it dry and cool. I have 100' HDMI cable I got for $40 that pushes 1080p to my projector just fine. If I were doing something like that, I would have to find a spot for the other connectivity advantages of Red Lion and use their Productivity Station for the big screen.
Hey folks! I've gotten an idea in my head and I'm wondering if anyone can help - and my title is terrible because I'm not good at articulating...
1,035
Looking to display data from the Factory Talk historian SE 4.0 on a screen in Factory Talk SE 8.1. Was wondering if anyone has run into this...
1,593
Hello my first time posting so hope i do not confuse you guys. I am wanting to store data from my vibration/Temp sensors that my PLC is already...
1,996
Hello Everyone, I am new to this forum and also new to PLC programming so please do bear with me. I have a Data Logging PC where i am using FT...
2,136
I want to display the results from a SQL SELECT statement inside intouch. Looking for some kind of example as the SQL Access Manager doc is not...
11,677
