DL340-Excel
atatari
Sep 2002
92
Hello everybody,
Has anybody imported data (I/O status-Register values)from DL340 to excel spread sheet?
what software do I use?
and how to do that?
If you are using DirectSoft, go to the View Documentation (Control-D). There is a file documentation export function - use the CSV (Comma Separated Variable) format. Then you can load it into Excel.
I use this if I am changing the nicknames on a lot of registers. I use the search/replace function in Excel, save the file in CSV format, and then re-import the variables from the CSV file into DirectSoft.
I think what you are looking for is a an OPC/DDE interface. Something on the order of DSData or KepWare. You can find both at AutomationDirect.com .
Alternatively there are several OPC/DDE servers that you can find with a simple Google search. Try searching for "Koyo OPC DDE Server" of try replacing "Koyo" with "PLC Direct" or "AutomationDirect".
Nuts, Icky - I must be getting early senility. I don't know why I thought he wanted to import documentation!
Sorry about that.
I am using TOP server from OPC power server using direct-net protocol ,but I can't communicate with DL340.
DSdata I beleive is from automation direct ,but this TOP server works the same.
any ideas?
Are you using "ApplicationName| TopicName ! ItemName" for the format?
Does the baud, parity, station # match what the CPU is set for?
Failing all else email Software Toolbox for technical support.
This is purely a personal project. I am building a my second homemade cnc router. This time going for a 5 axis. I want to use a plc for external...
2,458
I am trying to help a guy out who has a 10 slot base with this CPU and cannot manage to connect to program this PLC with DirectSoft32. There has...
3,357
Hi i wanted to know any guys have done Directlogic networking using DL 450 Series with DL350 series using the Fa-ISONET?? Currently i using...
3,418
Hello Everybody, We have an DL340 cpu whcih inputs 4-20 ma signal from scales to show the weights. Now this value needs to be subtracted from a...
1,697
I bought Dsdata (OPC server for koyo PLCs) to bring the data (registers-I/O statues) from DL340 and to Excel. Now my problem is how to share this...
2,841
