Do i need a memory card for a 1511 pn CPU?
Smeagol
Aug 2020
Mordor
Im implementing a 1511 cpu for the first time ever in my project and i was wondering if it requires an MMC card to run the programs off of.
Yes, you do.
The PLC has built in "work" memory that can't be expanded, which is used like RAM in your PC. The "load" memory is expandable (whichever memory card you select), and works similarly to the hard drive of your computer. When you download from Portal to the 1500, it downloads to the Load memory. Then it copies things into work memory when it's time to run the program.
The recommendation I've heard is to buy a memory card at least twice as big as you actually need, because if you need to download the whole project at once for some reason, it needs room on the card for all the new blocks before it can delete the old project data.
Supposing I want to be put a TIA Portal Project "executable image" onto a memory card (e.g. see picture). The reason for doing this is so that I...
392
Hi guys! Is the memory card a must on the Simatic S7-1500? At least the newer S7-300s could be run without a card even though some info on the...
6,551
Hi, I'm new to Siemens and have a program to write. To get me started I have bought a used S7 315 without a mem card. I have ordered one! In the...
3,047
Please help! The memory card was formatted by windows, PLC indicates "card err", how to restore it? Somebody has an image of a card?
2,671
Hi All, We are using a MicroLogix 1400 PLC in a double-sided lapping machine at my work. Unfortunately while the breaker switch was turned off...
2,805
