Do I need a shielded wire for 4-20mA signal?
Cryogen
Oct 2005
NH
151
I have a SLC 500 PLC with NI4 analog input card. I am using two 4-20mA signal coming from an RTD transmitter. The overall length of the cable is around 20ft. I have very limited knowledge in grounding and shielding. In my understanding, voltage signals are more susceptable to interference than current signals. So I am not sure if we need a shielded cable for this signal..
Please let me know what I should do.. Any documentation on basics of grounding/shielding would be helpful too..
Thanks for your time!
I would use shielded cable. Even if you don't have interference from any other source NOW, you might in the future from a new/changed process requiring components that would interfere with non-shielded wire.
Download this document from mrplc.com: EMC Guide
Help with selecting shielded cables:
Chapter 2 - Cables
Advice on termination of shielding:
Chapter 2 - Wiring Rules
Thanks for your replies.. It would definitely help me..
krk, I created a login on that site but still it doesn't let me download anything.. says
You Do Not Have Permission To Download Files In This Category
What should I do to see the files?
Thanks..
42
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
260
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
345
171
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
74
