Does 1761-CBL-PM02 work with any USB/Serial Converter?
Peacemaker
Feb 2004
22
Hi guys,
I am going to buy new laptop, which has no real serial port as you know. I am wondering if I can use 1761-CBL-PM02 with a usb/serial converter like Keyspan USA-19HS.
Thanks.
Though they are getting harder to find, you can still get laptops with serial ports. I just got a new dell Latitiude and we made sure it had a serial port and believe it or not floppy drive!
Just FYI
Marc
Peacemaker said:
Hi guys,
Thanks.
YES!
I've had no problems with any USB/serial converter. The micros arent that picky....It's the SLCs where you run into troubles...the UIC (bascially a usb pic box) is a picky device and takes some time configure and learn how to use..
my .02
While not many laptops have native serial ports anymore, i have never had a problem using a pcmcia serial card. Seeing how almost all laptops have either pcmcia or the new expresscard slots available, i would look at using either of these 2 options
Hi, I am new to Micrologix1000. I am using 1761-L16AWA. Does this PLC support half-duplex communication through serial link (using DF1 protocol)...
5,410
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
32
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
118
