Does AB 1734-EP PS occupy a slot in CLX IO Config?
wildswing
May 2005
Sault Ste Marie, Ontario
281
Hey fellas,
I've got a 1734 PointIO system that contains a few 1734-EP booster supplies mixed in with the other IO modules. When doing my IO configuration in RSL5000 (CLX L55) do these extra PSs occupy a slot number, or do I configure the IO modules as if the PSs weren't there?
On a POINT backplane, the 1734-EP24DC and -EPAC and -FPD modules do not communicate on the bus or take up a Slot number.
Only the Adapters (1734-AENT, -ADN, -ACN15) and POINT modules themselves have Slot numbers.
Hi: I have been using this module for years for my testing. Now it does not work and have no idea how to fix this. Will be very grateful for your...
11,035
I have two 1734-AENTR/B remote I/O racks attached to a 1769-L33ERM processor. Both racks are communicating; the inputs update in the PLC as...
3,108
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
46
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
40
