Does an addon instruction need external tag for output
mrgees100peas
Aug 2016
vermont
24
I'm creating a simple addon instructions with some inputs and outputs as you normally would (RSLogix 5000 version 20). When I add the instructions to a rung it asks me to put in a tag for the inputs and outputs. I understand the inputs but, why does it asks for the output. I don't want to use another tag for the output. I want the current instance of the addon instruction to be the output.
for example, imagine an addon instruction called WaterTank with an output parameter called Level. You instatiate 2 tanks and named them Tank1 and Tank2 using that add on. On another Rung you should be able to use Tank1.Level and Tank2.Level. However, in my editor each instance asks for a parameter tag so I guess i have to create another tag and put that in as in AnotherTank1.Level. What am I missing?
No worries- the term "required" isn't exactly intuitive that it means you must link to a tag instead of just type in a constant.
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
112
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
420
So, I'm really just trying to get some experience by practicing with arrays. I'm using studio 5000 v33. I have one rung with an XIC bit that's...
238
I tried researching but I still don't quite get it. As far as I understood, it's used after a function is called in STL and then if the function...
145
