Does anyone know about create own library or block in ProWORX NxT ?
Feb 2015
Bangkok
Would like to ask .. if anyone here know about creating own library or function block on ProWORX NxT ?
I have a backup of ProWORX NxT project which contain a special block (not come from standard library). The name of the block is "FN04".
I would like to know how to open and understand the function or description of this block.
Thank you.
Only had a little exposure to Proworx but I believe these are actually called Macros not functions so perhaps look for those, they work the same as functions or function blocks, you create a Macro, pass the addresses to it & write your logic.
Sorry I cannot be any more help
Loadable Library
Under Utilities-Loadable Library there are some blocks that have to be imported into the code. That might be where you will find what you are looking for.
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
420
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
811
Hi there, I need to work on a GE series 5 PLC which need DOS based Logic Master 5, it seems like nowhere I can purchase this software anymore...
955
Does anyone have a spare PacDrive part# LMC600CBD10000? Not necessarily for sale, but to do a bench test. I have a CF image file, and I'd like...
1,263
Hi all, Client called saying that the turbidity readout on the HMI is 0.0000 but on the local readout, it shows an actual value. Sure enough...
5,417
