Does anyone recognize this AMP plug?
Aabeck
Feb 2013
Detroit
1,860
I have a project to changeover some power supplies that the present ones are powered with an AMP plug & receptacle- see the attached picture.
I have searched the Amp website & can't find this type. The only markings are "AMP" and the connectors are numbered 1 to 4. It is a molded plastic 4 conductor plug with 2-part boot.
Does anyone recognize this & can provide the part # to find a matching corded receptacle?
It's not automotive, its 3 phase w/ ground. And my customer wants the option of changing back if the need arises in the future so they would prefer not cutting off the connectors, just mating to them with a corded receptacle to the different power supplies.
I just found out from TE (Amp) this is their High Current Commercial Connector. For a mate you would need to buy for each connection:
1) Plug Housing
2) Strain Reliefs
4) Terminals (for right wire size)
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
420
It's off a pallet positioner that doesn't have a name or model number. The body is all plastic. I epoxied it back together but that probably won't...
4,380
I'm trying to help with an asset inventory for a plant we might be taking over. All I have to go on is this photo. I've tried searching through...
2,740
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
813
Hi there, I need to work on a GE series 5 PLC which need DOS based Logic Master 5, it seems like nowhere I can purchase this software anymore...
955
