Does anyoneone know who makes this?
nehpets
Mar 2009
Wales
496
Has anybody come across one of these in their travels? It appears to be controlling a 18Kw Quartz(halogen)IR heater bank, by full wave semi controlled SCR bridge rectifier giving 0-240Vdc to the heating elements conrolled by 0-20mA input from a PLC.
I can't find any manufacturers name or part no. except the MAP133, extensive goole searches have not been able to locate such a beastie.
Just to add the machine this is on was manufactured circa 1984.
I'm hoping someone recognises it.
Steve
Maybe replace it with something completely new.
Does it have to be rectified DC ? There are many SCR heating controllers, but they usually simply chop an AC voltage without rectifying.
I think it's either something made for a completely unrelated industry or a company that's gone under.
I don't think I've ever seen those as a three phase unit though. Last one I've seen in the field was from OMRON, if it helps finding a new part.
Hi I dont recognise the manufacturer. Like others have said I would suggest speaking to someone like Watlow to source an alternative, it is a generic device so any similar perfoming unit would work. Of course confirm the panel footprint is suitable also
I've run across a couple of SCR controllers in the past that were private labeled but were actually Watlow or Eurotherm. If you can open up the controller you might get an idea of who makes it with a stamp on the board.
Yup, thats my next step, this is an old machine but keeps going, management are not keen on changing stuff on it, they just want to replace like for like.
Thanks for all the help, will keep looking.
Steve
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
32
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
117
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
427
