Does it matter where a profibus repeater is fitted?
uptown47
Feb 2008
Over there, next to those boxes
1,146
We are fitting a profibus repeater to a network and I wondered if it matters where it goes. Does it have to be at the farthest point of the network or anything? Or can it go anywhere?
Many thanks
Depending on the baudrate, the segments will have a maximum permissible length. The "best" would be to place the repeater right in the middle of an existing segment, halving the length on both sides. If that is not possible, then be sure that the repeater splits the segments in such a way that the segments on both sides are kept within the maximum length.
If it was at the farthest point, then the segment on the other side would be 0 meters. Are you sure you understand what the repeater does and how it works ?
Clicky <-- read it, it's nice
And no.
You can place it anywhere in the segment.
As long as you keep within the maximum lengths.
EDIT: Sniped by Jesper.... :D
Good Evening , I'm getting ready to add a few input and output modules to a 1769-L33 rack. The module's I'm going to add are 1769-IR6 ...
1,646
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
112
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
420
So, I'm really just trying to get some experience by practicing with arrays. I'm using studio 5000 v33. I have one rung with an XIC bit that's...
232
