Does Proficy Machine Edition supports 90-20/micro controller/platform?
Dave85
May 2011
Florida
I am looking to purchase a GE controller to practice on. I would like to know if the Series 90-20 or the smaller micro controllers supported by the Proficy Machine Edition programming software? note that I am currently using proficy machine edition. Thanks
I didn't see where you can select a 90-20 CPU when you start a new project in ME. I haven't tried importing a LM90 project that uses a 90-20 into ME to see what kind of message it gives you.
PME supports the Series 90 Micro as well as the VersaMax Micro. It doesn't support the GE Micro that preceeded the Series 90 Micro.
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
42
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
36
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
122
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
432
