Does SGDV Yaskawa Servo controller support PROFINET
Prince
Jun 2002
284
How should I order SGDV servo driver to be equipped with PROFINET. Do they really support PROFINET network?
What does "Command option attachable type (for rotary servomotors)" mean in the catalog?. is it the network option?
Do I need to order any special software for PROFINET communication?
I don't think the Sigma V series supports Profinet. I know for sure Ethernet/IP, Modbus, Mechatrolink, and I believe they are working on EtherCAT.
I also think there's a new generation of servo drives coming out, either way you'll probably have to contact your rep for details.
I am not aware of Yaskawa Sigma V (SGDV) series servodrives supporting Profinet. In addition to their own Mechatrolink bus and the good old analog/encoder interface, they have EtherCAT and (I beleive, still) DeviceNet options; both being available via "snap-on" option modules.
Now, their MP2000/MP3000 series PLCs (or motion controllers) do support Profinet, both as a controller and as a device. So your options are pretty limited: you may set up a PLC with Profinet module as a device and to program it to do the motions via Mechatrolink drop to an SGDV drive or drives.
How should I order SGDV servo driver to be equipped with PROFINET. Do they really support PROFINET network? What does "Command option attachable...
1,054
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
38
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
33
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
120
