Dot Matrix Printer
Wilkerson4492
May 2010
Kitchener
Can anybody recommend a dot matrix printer to use with an AB CompactLogix? It is going to be used to print out parameter changes and has to have serial communications. I also need to have some sort of feedback to the Controller if the printer is faulted, printing etc. I have used ribbon printers in the past to do similar but this customer wants a dot matrix. Thanks for your help.
I'm confused. Don't dot matrix printers use ribbons? Anyhoo, Epson makes serial printers in several varieties. They are a dying breed, though. Going with a name brand lets you buy the ...ribbons... at a major office supply store if need be.
I here you, it is customer specified. They want something with a continuous paper feed etc. If there are other options I am open to suggestions. I suggested to log the data to a database but this was apparently hard to validate and easy to change so they did not want to do it. I am looking to see if anyone has a specific brand they have used before with the feedback to the PLC I require.
Thanks Kenny, I'll have a look and see if Epson will work. I know Fujitsu and Okidata also make dot matrix printers, just not sure what other people have had success with.
Dear Experts Could you please tell me how I can print the alarms and events to the dot matrix printer directly when it occurs. I think I should...
1,719
Hello everybody, I have a siemens PLC (315-2DP) with CP340 to print to a dot-matrix printer using RS232. I am using the standard Siemens...
5,200
Hi, Currently my company is working on a project which involve printing machine. Whoever is in this field do PM me to work out a quotation on...
5,088
Hi All, Has any one used a Spectra display for plant data before? Like the one Here we are hoping to connect to an AB SLC 5/03 to display error...
2,096
What is the meaning of this analog expression? I understand the default dot field such as .Value, .Ack, .HiLimit etc. But I don't understand which...
1,624
