Downloaded FactoryTalk View ME 8.2 to Replace 6.10. Still only have 6.10.
Rob S.
Sep 2008
Maryland
739
Good Morning ,
I need to upgrade to FactoryTalk View ME to 8.2 , from 6.1. I downloaded 8.2 overnight . I rebooted , and went to open up FactoryTalk View ME Studio ,
and it is still 6.10. Do I need to do a separate install to update this to 8.2 ?
If so , what is the path to the install file , and method ?
By doing this , is there a risk of losing projects ?
Thanks so much,
This is an ordinary Windows Installer, not an automatic update service, so you need to find the downloaded file and execute it (maybe decompress it first, if it's in ZIP format).
On my computer, the RA download manager puts files into the directory path C:\Users\Public\Downloads\RA.
Once you install the new version and open a FactoryTalk View project, that project will be converted to version 8.2. While you can still create Runtimes for older terminal firmware or runtime installations, the project archives (*.APA) won't be open-able by development workstations running earlier versions of FactoryTalk View.
Since you're coming from v6.10, you have probably already cleared the 32-bit to 64-bit database conversion hurdle.
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
156
I downloaded rslinx classic lite v4.0 today only to find its not compatable with my version of windows 7 ultimate, anyone know what the mjst...
1,611
Whenever I download anything from rockwell automation it will not install. It downloads to the downloads folder but when I click to install I get...
2,067
Good morning guys! I have a doubt. I uploaded a program from a S7-200xp on the field and took it to the office. Before doing any test I tried to...
2,181
Downloaded RS Logix 500 , now cannot open Rockwell Software"Error Logging Security" I have RS Logix 5000 and Factory Talk View Studio , and it...
10,492
