Dox10 software serial driver
jed
Jul 2006
Leeds
22
I have Dox10 3.3-0 which is telling me "No serial driver loaded Please check your CONFIG.SYS" when I try to select "Send to PLC" or "Rec. from PLC"
Does anyone know what I can do to resolve this as I need to backup several PLCs next week?
Dox10/dox5
HI,
Havn't used DOX10 as I use DOX5 if I have to.
Are you running on a W95 machine or an older machine with real DOS?
Are you using a serial port rather than usb/serial.
Have you set the config.sys
Regards
Robin
Add the following line to your Config.sys (or more likely, config.nt) file.
DEVICE=\DOX10.SYS\V24.SYS R2048 S255 Ca Abbbb Icc
Ca is the COM port number C1,C2,C3 or C4
Abbbb if COM3 put A03E8 if COM4 put A02E8 else put nothing
Icc if COM3 put I04 if COM4 put I03 else put nothing
USB to Serial converters will work with DOX10. RSLinx, if it is running, might grab your COM port and DOX10 won't be able to access it, so turn off RSLinx.
Good Luck
DOX10 serial driver
Thanks for the reply.The config.sys file contains the "device=..." as you stated. I am running it on windows 2000 is this the problem?
Sorry for the late reply.
Windows 2000 isn't your problem (I have used it with DOX10 before). But I thought that Windows 2000 uses a file called "config.nt" instead of "config.sys". This file is located probably in C:\windows\system32\
Also "autoexec.nt" is used instead of "autoexec.bat"
Perhaps if you post your config and autoexec files, we could check the other settings for DOX10.
does any body have this ABB v3.3 or 3.4 software??
1,330
Hello, I'm looking for a manual for DOX10. Does anyone have a scanned copy or can guide me to a copy on the internet. I'm trying to convert a...
1,866
Hi, Does anybody have a user manual for DOX10 programming software? I have an old copy of the software but not the manual. I need to view an old...
1,443
Good day everybody Hi I currently have a smart little doc for dox5 but I'm working in dox10. I was wondering if someone has a smart little doc...
2,729
