Drilling at ex panel
shkoko2000
May 2011
cairo
296
Dear all,
Is there any standard or any way to drill in an ex panel to add a new componant without making this panel not ex.
Think about it. Let's say you have an ATEX panel in a, for example, flameproof enclosure. Even a small scratch between the openings will make the enclosure very much NOT flameproof.
Drilling a whole in it is certainly not going to make it more flameproof.
But what is the protection principle of the panel?
If you aren't sure of what you do with xproof stuff, you may better get it done by certified company. Usually any function change that you makes to a certified control panel will usually cancel that certification.
Things are probably a bit different for European rules but usually holes are factory made to customer request. We do it on machining equipment.
I'm not the machinist but i expect you need it straight and the hole size must respect what is needed for the thread pitch and size to be taped in with the proper tap. I would be afraid seeing someone trying to do it with a standard hand drill.....(It isn't not like a hole in a 14gage steel plate where the connector pass thru and you secure it with a nut....)
There is other things to look for also, the part screwed there must meet the same requirements. You also need to know if you are feeding device in the xproof zone where you could need some added safety method of protection...
I forgot what the material was call but we use to pack it around all the entry points it was also fire rated and we had positive pressure in all the cabinets
Are you just installing it or doing mod's in a working cabinet ?
Rox Blocks from Roxtec?
If the panel or junction box is flameproof (Exd), you can't touch it and need to maintain it in its original state.
If the panel or junction box is non-sparking type (Exe), you may open a whole if the box was made and certified for that hole.
It is fairly common, for example, in Hawke boxes that it only comes with 2 holes opened, but there are marked holes on the other two faces that can be opened (according to the manual) and used with the correct protections for the area/circuits.
Seen as you are unsure, I wouldn't touch it and just get someone that knows about this sort of thing to solve this issue.
May have been, its been about 10 years, when it comes to EX they are all case by case, ours was a little overkill but whatever we only had a few fires :eek:
But... we had both a fire proof barriers that were sealed and purged and EX cabinets that were sealed and purged, but I agree when it comes to this stuff at minimum hire a firm to come in a tell you what you need to do to stay safe. We also had our signal wire fused so it could not arc, it was a pain to work on.
Short of levels 1-4 I think COMPEX hasn't quite taken off in the US but level 12 is, although an immense amount of information to digest, very good at understanding all the little complexities of hazardous area equipment.
It also helps if the guy or guys giving the course happen to write and contribute to the standards...
For the OP... I know your not in the US but, here is some reading material
HERE
Im sure its covered but 900 pages of fine print is a lot to read
One of our work projects involves creating a "peck cycle" on a drill press using a servo motor. The servo will be direct driven off of the drill...
2,786
Hello everyone, I have a aplication where is needed to add a drilling unit on a cathezian system. Do you know any provider of this kind? Thank...
1,781
hi every one... i dont know if u are familiar with what iam going to say ,,but iam going toask any way .... iwant to know the using of plc in the...
3,364
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
83
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
210
