Drive exec does not see smc softstart
Read the Knowledgebase article #29926. You likely have the wrong version. But you may want to just change over to CCW For programming, Drive Executive is not going to be kept up to date with any changes from here on out so as time goes on it will be less and less useful.
Something to look into. New systems we put in will probably face similar problems. I am be fuddled. When I direct connect my laptop through Ethernet cable to drive port dExec finally saw it. Even though rslinx could even over wifi before. Something goofy is afoot.
I have two PC's with Rockwell Software running on them so I can access the same equipment and files using rslogix5000, device net and drive exec...
1,082
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
215
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
53
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
48
Hello everyone, my son and I are working on building a metal lathe. I been waiting for a motor/speed controller donor from a treadmill. I finally...
49
